13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- What is the statistically proven safe border ( close to 100ms ) for a safe custom board enumeration in any PCI? --- Quote End --- There is none :( PCI and PCIe are used in desktops, industrial backplanes (cPCI and CPCI-S.0), etc. The power supply designs for all of these systems are different. --- Quote Start --- In what references can I read about it? --- Quote End --- Read the references linked to on p4 of this document: http://www.ovro.caltech.edu/~dwh/wbsddc/ts4_power.pdf Some of those documents require buying the specifications, but if you're going to design boards, you need the specifications. Cheers, Dave
