13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- A MAX II CPLD plus a QSPI flash can easily operate at 12MHz, this means with FPP mode, there is no problem meeting the power-on requirement. MAX II CPLD EPM240M100C5N $6 --- Quote End --- I was considering that possibility. MAX II CPLD with PFL inside / QSPI flash / PS mode for EP4CGX22 / Configuration mode only won't fit into EPM240M100C5N. EPM540M100C5N @ 13.5 USD has to be used ... A more comfortable Configuration + Programming mode won't fit even into EPM540M100C5N. EPM2210 @ ~30 USD has to be used ... Are You sure, that PFL input Clock = 12MHz clock is enough for MAX II to configure EP4CGX22 from a single Quad SPI ( N25Q128A13ESE40G ) in PS within below 50 ms ( as a conservative approach )?
