13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- Arguably tRAMP is tPOR(min), so you could just use tPOR(max) = 9ms. --- Quote End --- This is what I mean. --- Quote Start --- However, if you're within 3ms of the 100ms requirement, you're too close, and your system would likely fail in many systems, since even the 100ms value is not a guarantee. Read the references in the PDF link I gave above. --- Quote End --- What is the statistically proven safe border ( close to 100ms ) for a safe custom board enumeration in any PC?I UPD: In what references can I read about it?
