13 years agoFPGA configuration time and PCIe secification
Has anyone used the PCIe interface of a Cyclone device while configuring it using the AS (active serial) scheme? I'm using a Cyclone IV device (EP4CGX30F484) and planning to use its PCIe interf...
12 years ago --- Quote Start --- Compression might help you get under the limit. If your PCIe end-point logic will never change, or is completely under your control, then you could use this scheme. --- Quote End --- Yes, this is my case. --- Quote Start --- ...but by the time you add in the POR delay, and any power supply delays, eg. due to hot-swap controller or power manager IC, then you might be out of time. --- Quote End --- Now getting back to the very beginning to what I was asking for: What timings ( POR-related, etc. ) I have to add to calculate that extra time? Meanwhile, I'll try to get more info about CLKUSR mode to clarify if its possible to set DCLK=40MHz.
