17 years agoFPGA Configuration Problem
A strange one here. I'm trying to power up a Cyclone III EP3C10 in active serial mode, and even before the device tries to access the PROM it drives all I/O pins low and does not make any attempt at...
17 years ago --- Quote Start --- If it's an EQFP144 device, did you connect the enhanced pad to GND? --- Quote End --- I just saw that pad. No, it is not grounded, but I can set that up pretty easily. Altera really doesn't draw enough attention to that pad if not connecting it can kill the entire part. --- Quote Start --- What are your MSEL pins set to? Jake --- Quote End --- --- Quote Start --- And how are the MSEL pins wired? --- Quote End --- MSEL[2:0] is 010, and the lines are tied direct to GND or +2.5
