17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
12 years agoHi,
I am trying to reconfigure the flash in one of my FPGA board and it is a cyclone 3 starter kit. I found this procedure in one of the posts in our forums. I have attached the pdf . The procedure is in page A5 of the pdf . But while reconfiguration i am facing a problem! After step 6 while performing step 8( change file) the CF1_128 file is automatically getting replaced by CFI_16 file . The program gets loaded successfully only 71% after which the loading stops. If any one can guide me as to why this is happening, i will be grateful! Thanks, ivads
