17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
16 years agoHmm, got another problem.
Now I recompiled pfl2 example, programmed EPM570 device. Now, in quartus programmer I see both EPM570 and CFI_512MB flash device attached to it. I can even read it (via examine feature) and it seems looks good. But I cannot neither write to it, nor erase:
Info: Started Programmer operation at Thu Apr 22 06:45:51 2010
Info: Using default flash programming values
Info: Device 1 CFI Flash 1 is unknown Spansion device (16 bits data bus)
Info: Erasing CFI Flash configuration device(s)
Info: Programming status: erasing flash device 1 (unknown) at device chain position 1
Info: Programming status: erasing flash memory at byte address 0x00000000
Info: Programming status: erasing flash memory at byte address 0x00020000
Error: Erase failure on device number 1
Error: Operation failed
Info: Ended Programmer operation at Thu Apr 22 06:45:59 2010
Where the problem might me? In flash_loader macrofunction?
