17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
16 years agoI have the same board you discussing.
But my problem is that when I connect it via JTAG, run programmer and click "auto detect", I see a list consisting only of EPM570 and EP2SGX90. There is no CFI_512MB. So probably I need to configure EPM570 correctly. What correct .pof should I use?
