17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agoHi,
first of all, when you change the version of the PFL, you don't have to worry about the assignments, as long as you are using the original Quartus II project. This will guarantee that all the assignments are inherited properly. If you install the development kit CD at the default location, you will find the factory default project and other useful files under: C:\altera\Kits\SIIGX_PCIe_Kit-v1.0.1\Examples\ManufacturingTestDesigns I use the s2gx_pcie_top as the reference design. Cheers,
