17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agohi ,
Actually i too faced the same problem of version . In ref. to ur prev comment,where u have mentioned about generating a new PFL using quartus 8.0V . There u might be assigning the pins of MAX to Stratix. I was reffering to those assignments. anyway i have used the PFL.qar to generate the project and tried to configure it but in vain .:o :o :o U keep on referring factory default config, and factory deafult SOF what does that refer to ? Anyway I am trying with all possible ways of configuring it... Hearty thanks for ur efforts
