17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agoHi,
actually, you don't have to worry about the PFL project assignments, as long as you are using the one, which is delivered with the kit. If you install the CD, which was included in the kit, you should be able to find the archive of the original project under: C:\altera\Kits\SIIGX_PCIe_Kit-v1.0.1\Examples\ManufacturingTestDesigns\pfl2.qar The only reason to modify this project was that the PFL macro had to be upgraded from v2 to v3 (see one of my previous posts).
