17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years ago:) A hearty thanks to csaba. But the sad part is i'm still not able to configure the fpga.:o
I have quartusII6.1 fullversion. I tried the procedure given by u , using it. Then i shifted to quartusII7.2 web edition, but couldn't get the desired result. Can u tell something about the PFL generated by U and it's pin assignment. Do we need to take care espcially, any pin ? I have just mapped the pins of my PFL to the MAX II pins as mentioned in user guide. or Can u send ur project file. That could be of greta help. regards,
