17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agoI don't know what could be wrong, but I can give you some hint.
Can you see the conf_done LED (D8) switched ON after pressing S1 ? (It is a green LED near the S1 button.) Did you consider that when the S6 is switched 'ON', it actually pulls down the appropriate signal ? That is, 'ON' position means logic '0' ! If it is still not working, I will detail the procedure, which works for me...
