17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agoi'm back with some new findings ...
looking into the firmware of the configuration controller (PFL), I found this comment: //+----------------------------------------- //| Parallel Flash Loader (PFL) Megafunction //| //| Flash Size: 512Mb CFI (Spansion) //| Flash Data Width: 16 bits //| Option Bits Addr: 0x1FF.0000 //| Clock Speed: 100MHz //| Retry on Error: Same Page So, it seems that option bits address should be 0x1ff0000. However, in the reference manual (Table 2-8, page 2-16) the PFL option bits are at 0x3fffff0. I'm really confused. :confused: By the way, the flash image (pof) that I create with Quartus II v8.0 SP1, is not accepted by the programmer, because the PFL version of board configuration controller is v2, instead of the expected v3. :eek:
