17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years ago --- Quote Start --- If I recall correctly, the flash loader that comes in the MAX device has a dependency on one of the push buttons. I think you have to press switch S1 to allow the flash programmer to continue on to program the part. It's been a while, but I don't think the flash loader will even detect that there's a part out there unless the button is pushed. One other thing I recall about digging through this: The documentation wasn't very clear about this push-button. --- Quote End --- A bit more info on this... If you try to auto-detect the JTAG chain from the Quartus programmer and you get this message: Info: Device 1 silicon ID is not ready - waiting for pfl_flash_access_granted to be asserted the Parallel Flash Loader in the MAX II device is witholding access to the flash. It will eventually time-out with an error message: Error: Failed to get access to the flash interface If you press button S1 before the time-out, your auto-detect will come back with the MAX II 570, a 512 MB CFI Flash and the 2SGX90. You should now be able to communicate with the PFL and start programming. I couldn't find anything in the board's reference manual that discussed this, but there's a note in the readme.txt file that get put in teh docs directory when you install the CD that came with the kit.
