17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agoPlease refer to the user manual for your board ...
http://www.altera.com/literature/manual/mnl-s2gx-pci-express-devkit.pdf The MSEL pins determine the configuration mode for the FPGA. Table 2-7 in the user manual details the option for your board. You have to set the pins correctly for it to work. In addition, your board has Mode DIP switches and the RUnLU switch. These must be set accordingly. When I asked if your MAX pin assignments were correct I also meant the configuration pins to the FPGA. Doesn't do much good to be able to load the flash if you can't talk to the FPGA. Table 2-10 in the manual details the required signals. Jake
