17 years agoFPGA Configuration problem using Flash Memory
Hi All, I am trying to configure my FPGA through Flash memory. Though my flash memory is getting programmed successfully, the fpga is not getting configured. Can anyone suggest me what could be...
17 years agoIs this a custom board?
What configuration scheme are you using? Are your MSEL pins set accordingly? Are your pin assignments all correct for the MAX device? Are you able to program the FPGA via JTAG? Jake
