14 years agoFPGA code for elevators(graduation project)
hey everybody, im new to this forum as im new to altera and FPGA language.. i have been taking a course in univerisity ( 4th year telecom engineering) called "architecture of micropocesser and op...
14 years ago --- Quote Start --- *why im not doing a project related to telecom: it's just because in lebanon, telecom field is a bit limited, and our studies programs is more focused on FPGA, open source systems, and embedded systems. plus, the dean of the faculty has gave us some themes for the project this year, like embedded systems, intelligent embedded system, 3D stereo, signal treatment with FPGA (witch is interresting,specialy if i want to do a project replated to the medical field), and websites. --- Quote End --- It does not matter where in the world you are. The key is to pick a thesis topic that you are interested in, and ideally one in which you have a local resource (eg., your supervisor) to help you. --- Quote Start --- *is elevator on fpga will be my project?: im still not sure, im doing alot of researchs about it and about others stuff and themes too but i thought about it because my uncle works in it, and he may help me to find an added value to work on. --- Quote End --- Ok, since you have someone to help, it might be good. First you have to describe what you would be doing with elevators. Just checking the buttons is a bit limited in terms of what you would learn. So, would your FPGA be used to control the elevator motors, or perhaps communicate the elevator location and motion parameters to a control system? Perhaps the FPGA could be used to control the elevator motion, i.e., from a stop, accelerate at a specified rate until reaching a specified speed, and then decelerating to reach the desired floor. The design has to be complicated enough for you to learn something practical. --- Quote Start --- *i thought about signal treatment for medical field because its really interresting, but in medical field i need a scientific parameters that is not easy to find online. --- Quote End --- You can always create an analog to a medical signal processing task. For example, ultrasound and sonar are similar. You could create a robot path finding algorithm using an ultrasonic sensor, and that work would be similar to medical sonar (in some respects). --- Quote Start --- *thanks to you now i will start doing some research about digital madulation using FPGA, but i would like to ask if there is any resources that may help me to find the motivation that it will lead to a good project with an added value that can be successful in the market, and helpful to other students. --- Quote End --- Talk to your supervisor and ask whether creating some resources for future students would be helpful to him. If you can create a good set of resources, then you will please your supervisor, and learn a lot in the process. --- Quote Start --- finding a good project with an added value is not easy, specially that online resources is not enough. --- Quote End --- Create a set of proposals, and give them to your supervisor. Make sure to provide enough detail on what tasks you would perform to complete the thesis. That process will likely help you decide which one is of most interest to you too. Cheers, Dave
