RobertOlson's avatar
RobertOlson
4 years ago
FPGA Arria® V -FA support request for Honeywell- 5AGXFB3H4F35I3G- 1pc
Form #: 2142792
BEI Part #: HWL52000859-49
Mfg. Part #: 5AGXFB3H4F35I3G
Purchased from Arrow Electronics
Original PO #: WPM285806
Quantity to return: 1
Date code: 2137
Reason for return: rejected by pre-inspection for damage to pad side with lifted mask
  • RobertOlson's avatar
    RobertOlson
    Hi Wani,
    This part is a fresh, unused unit. It has not gone through any processing or testing.
    The physical damage was found prior to use- damage to pad side with lifted mask
    Thank you,
    -Rob Olson
    507-535-4083
  • Zawani_M_Intel's avatar
    Zawani_M_Intel
    Hi RobertOlson,
    Good day!
    Thank you for contacting Intel FPGA Community Forum.
    Can I know the status of this unit either it is fresh raw unit or it is undergone several other test?
    Thanks!
    Wani
