FPGAのパワーオンリセット不良
インテルのFPGAにはパワーオンリセットが実装されているかと思います。
FPGAが実装されているボードにおいて、
電源OFF後、ONまでの時間が例えば数100mSec等と極端に短かった場合、
パワーオンリセットによるロジックの初期化が行われず
設計とは異なる意図しない論理、具体的には出力が固定されて変化しない。また
入力信号の変化を受け付けず固定される等、誤動作が発生する可能性は
ありますでしょうか?
ちなみに対象のFPGAはデバイスは、
10M08DCF256C8G (MAX10)
10M04DCU324C8G (MAX10)
- Ash_R_Altera
As we did not receive any response from you on my previous comment, I am setting the case to closure. However, it will still be open for the community members to comment on.
- Ash_R_Altera
Please refer to MAX 10 datasheet: https://www.intel.com/content/www/us/en/docs/programmable/683794/current/internal-configuration-time.html
The required configuration time is in tens of ms as compared to hundreds of ms as you mentioned in your description. This means, that the device might have already been in user mode by the time you turn off again.
Also, to note that MAX 10 devices support hot-socketing. Refer, https://www.intel.com/content/www/us/en/docs/programmable/683400/18-0/hot-socketing.html
Request you to please reply in English for this ticket. I had to use translator to understand your query.
