Format of initialization file for MAX10:UFM simulation
Device: MAX10 10M02SCE144
Environment Windows 11/Quartus Prime Lite 17.0/ModelSim ALTERA STARTER EDITION 10.5b
I am using Altera On-Chip Flash IP. I want to set the initial values for my UFM. I understand that for a real device, the initialization file should be specified as .hex or .mif. However, I do not know the detailed format of the initialization file .dat for simulation.
According to the flash memory user guide, the format of the .dat file is "32-bit data width file: use word address". But is this file binary or text? If text, what are the delimiters? All these details are unknown.
Can you please give me the details of the .dat file? A sample would be even more helpful. Thank you in advance.
- Farabi_Altera
Good to hear you solved the problem. I will return this case back to community.
regards,
Farabi
- ken_51
- Farabi_Altera
I am sorry i just realized you are using MAX10. Let me check and get back to you again.
regards,
Farabi
- Farabi_Altera
Can you refer to this link : https://www.intel.com/content/www/us/en/docs/programmable/683130/24-1/simulation-for-on-chip-memory.html
regards,
Farabi
