18 years ago
format conversion
how to convert from std logic vector to integer?
and
how to convert from sfixed to std logic vector ??
:confused::confused::confused:
    vernmid thanks alot for your help!!!!!!! rili thanks alot!!! i will try it out!!!
    Loads of good info here...
    www.synthworks.com/papers/vhdl_math_tricks_mapld_2003.pdf
    (Hope its OK to post links here, if not I will delete if requested :)
    Top tip....
    Alwyas use the package
    use ieee.numeric_std.all
    for all new designs.
    For integer to std_logic_vector to you need to convert to unsigned (or signed) first
    signal A_slv : std_logic_vector (7 downto 0) ;
    signal Unsigned_int : integer range 0 to 255 ;
    Unsigned_int <= to_integer( unsigned( A_slv ));
    Good luck
