ZLu001
7 years agofor Cyclone V, Can't configure EPCS64 by .jic file using USB blaster.
.sof is OK, for Cyclone IV and EPCS16 is OK. For Cyclone V and EPCS64, all MSEL pins are grounded. Error message: "Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID ...
JohnT_Altera
7 years agoHI,
You need to change the MSEL to AS configuration scheme. Then you will be able to use .jic file to access the flash. POF file is not supported using JTAG interface.
