ZLu001
7 years agofor Cyclone V, Can't configure EPCS64 by .jic file using USB blaster.
.sof is OK, for Cyclone IV and EPCS16 is OK. For Cyclone V and EPCS64, all MSEL pins are grounded. Error message: "Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID ...
JohnT_Altera
7 years agoHi,
You mention that you are using blaster and work okay with sof file. May I know if you only connect it to JTAG interface?
If you would like to use pof file, then you will need to be able to connect the blaster to the Active Serial interface in order to directly configure the flash.
