ZLu001
7 years agofor Cyclone V, Can't configure EPCS64 by .jic file using USB blaster.
.sof is OK, for Cyclone IV and EPCS16 is OK. For Cyclone V and EPCS64, all MSEL pins are grounded. Error message: "Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID ...
JohnT_Altera
7 years agoHi,
May I know if you are using blaster directly connected to the EPCS64 flash using Active Serial interface? If yes then it is possible.
If you are using JTAG connection then you cannot use POF file. You can only use JIC file to configure the EPCS device through FPGA.
