14 years agoFmax for generated clock on Cyclone III EP3C120F780C7
Hello, I'm working on a design which has a 125 MHz input signal. I have a small part in the FPGA which I wanted to clock with 375 MHz. I've created an altpll module using the MegaWizzard Plug-I...
14 years agoYes this should be possible. The tricky part will be after those blocks, when you will have to synchronize the outputs of all 3 stages in a single clock domain, as the timing may be tricky. You way have to use multicycles on some paths, or some synchronization primitives.
