14 years agoFmax for generated clock on Cyclone III EP3C120F780C7
Hello, I'm working on a design which has a 125 MHz input signal. I have a small part in the FPGA which I wanted to clock with 375 MHz. I've created an altpll module using the MegaWizzard Plug-I...
14 years agoI don't know what your block is supposed to do, but as it is rather small, you may be able to parallelize it, using several blocks running at a fraction of the frequency.
