14 years agoFmax for generated clock on Cyclone III EP3C120F780C7
Hello, I'm working on a design which has a 125 MHz input signal. I have a small part in the FPGA which I wanted to clock with 375 MHz. I've created an altpll module using the MegaWizzard Plug-I...
14 years agounfortunatly not.
But to get those high speeds you need to highly pipeline your design with minimum (1 LUT max) between registers.
