15 years agoFloating Point with Fixed Point FPGA
Good day.
I know this has been discussed a lot, but each situation seems different. I want to implement trigonometry functions on a Fixed Point FPGA. Can you please assist me with some tips as to how to go about this. I figured a lookup table may work. Does anybody have any tips or examples. Kind regards3 Replies
Thank you very much.
I have'nt worked wih CORDIC, but quick research shows this to be promising. I will research a bit and try an implementation. Your help is appreciated - Altera_Forum
If processing time isn't an issue, CORDIC may be an alternative for high resolution trigonometric functions. Or, even more simple, but slower, power series, the classical method used by numeric co-processors and software float libraries.
Look up tables are the way to go if you have few input/output bit.
In case 8 bit input and 8 bit input you get 256 byte of memory that is more than reasonable. With 16/16 you get 128Kb of memory, that starts to be difficult in a low cost FPGA.
