10 years ago
Floating point addition in vhdl
Hii
I want to add 4 floating point no.what will be the result range.I am using
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
this package.For example if I want to add two floating point no then the result range is
C= A+ B -- range of C is (max(A'right ,B'right)+1 downto min (A'left ,B'left))
and it is working fine .But when I am doing
C = A+B+D+E;
What will be the new C range.
If I am following the same as above I am getting an error
"D:/214ee1411/vhdl codes/floatarith/mul_1test/fmul_1.vhd" Line 50: Expression has 11 elements ; expected 9
Please help me with this.
Thank you
    --- Quote Start ---
    Yes, now you've added brackets, it will only need 2 extra bits.
    But a+b+c+d will break down into:
    result := (((a+b) + c) + d);
    which does require 3 extra bits.
    --- Quote End ---
    I concur.
    But getting pedantic: each addition will generate an extra bit, so if n additions are concatenated (as you describe) the final addition delivers n additional bit. But the result only needs integer(ceil(log2(n))) extra bits so you can resize:
    signal    a, b, c, d : ufixed(HH downto LL) ;
    constant NN : positive := 4;
    signal    result : ufixed( HH + integer(ceil(log2(NN))) downto LL);
    result := resize((((a+b) + c) + d),  HH + integer(ceil(log2(NN))), LL) ;
