15 years agoFloading Point divider, throughput/latency
Hi all, I'm considering using the floading point blocks available from Altera in a design I have. Throughput is a top priority as I'm doing complex image transformation for high speed application...
15 years agoHi nplttr,
I'm fully aware of this. My experience is 3 years ASIC design (front-end and back-end design) and ~1 year FPGA design with Altera devices. In this example when I use the rising edge then the data has a full clock cycle to become stable before it is registered into the divider. How ever if I use falling edge the data only has half a cycle... I prefer to keep my design synced on rising edge unless I have a really good reason to switch over to falling edge. To place this buffer into the design will also cost my 64 registers + some additional logic. I wander if this is a bug in the behavioural code for the divider and if I have to do a gate level simulation for this... Cheers Stefan
