15 years agoFloading Point divider, throughput/latency
Hi all, I'm considering using the floading point blocks available from Altera in a design I have. Throughput is a top priority as I'm doing complex image transformation for high speed application...
15 years agoThere's something I don't understand.
I run a simulation of your circuit using the attached testbench. If I read weel you're doing the operation 10/512=0.19... and 512/10 =51.2. I used your function : div6_result_real <= float32ToReal(div6_result); to display the results and it looks correct. You can run the simulation and let me know.
