12 years agoFlex10K and EPC2 configuration Error - Flex10K in continuous Configuration loop.
Hi All, I am new to Altera. I have a board with Flex10k30 and an EPC2 to configure it. I also have a DSP (ASDP21060) on the board which uses Flex 10k. I have recently run into an error in...
12 years agoYou can stop the configuration loop by pulling nCONFIG low.
There is a setting when you create the EPC2 .pof image that indicates whether to retry configuration on error. Turn that off and you will not get the repeating loop. You can program the EPC2 and then verify to confirm its contents are correct. Which version of Quartus are you using? Cheers, Dave
