12 years agoFlex10k - LE optimization?
Hi! Aside from cranking all the settings up, is there any tribal knowledge / best practices about LE optimization for ye olde flex10k? One odd thing I found, as mentioned earlier somewhere, was...
12 years ago --- Quote Start --- I take it the compiler doesn't recognize this by default when you create a counter? --- Quote End --- The counter function typically gets detected ok, its the detection of zero that often causes a comparator to be created, rather than inferring the use of the carry-out. Try it and see, i.e., use the lpm_counter and carry-out, and then code the same using one of Altera's recommended templates. Post what you find :) Cheers, Dave
