14 years agoFlex 6000
I understand that the Flex6000 series is a little outdated but its all I have to work with at the moment. I purchased the ByteBlasterMV and have both QuartusII 9.0sp2 and 12.0. What Im trying to do i...
14 years agoHow is the Flex6K configured?
Via EPC1? If so, you can read back the PROM contents via JTAG. Unless it has been programmed with read protection. If you're using some other configuration scheme... then that will depend on the scheme.
