16 years agoFlex 6000 clock gating
Hi I've been converting a 10 year old non-synchronous design to make synchronous so that it is more robust. Due to the available clocks on the board, it is necessary to use a gated clock. The o...
16 years agoThe gated clock is going only to a pin on the device for an external circuit, and clocks nothing internally. The clock in this legacy design is not fast enough to achieve the external data transfer without a gated clock. I have to change the contents of a data bus every clock cycle, and provide a negative going pulse, midway between data bus changes to transfer the data. Data is not transferred on every clock cycle though, so the pulse needs not to be present some of the time.
I have found now that the gating circuit operates correctly for speed grade 2 (which the design uses) and 3 Flex 6000 devices. I still don't get why the speed grade 1 devices glitch though. Cheers Gordon
