19 years agoFLEX 10KA. The Dual-Purpose Configuration Pins
Hi All !
FLEX 10KA has next Dual-Purpose Configuration Pins: nWR, nRS, nCS. CS, RDYnBUSY and CLKUSR. I need to use these pins as Tri-State input-output pins (bidir) during user mode (for connect to the data-bus of RAM). I use Assign-> Global Project Device Options… for configuration these pins. But MAX+Plus II helps for Dual-Purpose Configuration Pins in “Help->FLEX 10K and ACEX 1K Global Project Device Options Dialog Box”, that if the Tri-State option is turned ON “the pin is not used as an I/O pin in during user mode”. Question: Can these pins work as user’s Tri-State (and only) input-outputs? Thanks.No RepliesBe the first to reply
