tato_pt
1 year agoFlashing NiosV on EPCQ-L 1024 on Cyclone 10 GX Development kit
I need to boot the a Nios V C code into the Cyclone 10 GX. I have been able run a simple Hello World program during run time from the RiscFree IDE but now I want to turn on the development kit and ru...
tehjingy_Altera
1 year agoHi
For Nios V you could follow the link below for the steps for booting from a flash device:
The IP you should add is the Serial Flash Controller II for the selection of the EPCQ flash.
You could either use the Generic Serial Flash Controller or the Serial Flash Controller II. I would suggest you to use the Serial Flash Controller II instead of the Generic Serial Flash Controller.
They are both able to interface with the flash but the Serial Flash Controller got the setting preset for interfacing with the EPCQ Flash.
p.s. for searching Nios V document, place a space between the Nios and V.
Jingyang, Teh
