17 years ago
Flash Test
hi everybody,
iam using a nios II system generated from sopc builder.my system contains
a CFI FLASH and SDRAM.Iam trying to simulate THE MEMTESTC.C exemple from the IDE.the sdram test is allright but the flash test is not.
I have an error in Modelsim "
-ERROR: Could not open flash
i think that the problem is in the function
alt_flash_open_dev witch don't recognize the flash
i changed the code a little bit to be a ble to simulate
static
void TestFlash(int mode, int flash_type)
alt_flash_fd* fd;
int number_of_regions;
int block;
int y=0;
flash_region* regions;
int ret_code = 0x0;
// alt_u8 entry[4];
alt_u8 flashname[30];i replace this variable by CFI_FLASH_NAME
printf(
"\n get flash name\n");
ret_code = GetFlashName(CFI_FLASH_NAME,CFI);
printf("\n openning the falsh\n");
fd = alt_flash_open_dev(CFI_FLASH_NAME);
if (fd)
printf(" -Successfully opened %s\n", CFI_FLASH_NAME);
/* Get some useful info about the flash */
ret_code = alt_get_flash_info(fd, &regions, &number_of_regions);
if (!ret_code)
printf(" -Region 0 contains %d blocks.\n", regions->number_of_blocks);
block = FlashFindErasedBlocks(fd, regions, number_of_regions, mode);
/* If we're in TEST mode, ask if this block is okay to test. */
if(( mode == TEST ) && ( block != QUIT_WITHOUT_TESTING ))
printf(" -Block %d, at address 0x%X identified.\n", block, (regions->offset + (block * regions->block_size)));
printf(" -Would you like to test this block? (y/n)");
//GetInputString(entry, sizeof(entry), stdin);
y=1;
// if ( entry[0] == 'y' && entry[1] == '\n' )
if(y==1)
/* Test that Flash! */
FlashRunTests(fd, block, regions);
printf(
" -Closing flash device \"%s\".\n",CFI_FLASH_NAME);
alt_flash_close_dev(fd);
else
printf(
" -ERROR: Could not open %s\n", CFI_FLASH_NAME);
i tried a lot of things and i get the same result
if somebody have an idea about how to solve this problem please HELP ME
http://www.alteraforum.com/forum//proweb/misc/progress.gif
    sorry but i didn't understand what u mean by "remove/comment out the following line:" my problem is that the function
    alt_flash_open_dev return 0X0 that's mean that it don't recognize the flash device.
    i am just simulating with modelsim
    You are passing the constant define location of CFI_FLASH_NAME, and it may/will get overwritten when you call function. Try that and see what happens.
    kevin
