17 years agoFlash Test
hi everybody, iam using a nios II system generated from sopc builder.my system contains a CFI FLASH and SDRAM.Iam trying to simulate THE MEMTESTC.C exemple from the IDE.the sdram test is allrig...
17 years agoremove/comment out the following line:
ret_code = GetFlashName(CFI_FLASH_NAME,CFI); You are passing the constant define location of CFI_FLASH_NAME, and it may/will get overwritten when you call function. Try that and see what happens. kevin
