MuralikumarM
5 years agoFlash size selection for the S10TX2800 device configuration
I want to select the flash part for the configuration of intel STARTIX10 TX 2800 device,
as per device data sheet table 104 shows 577Mbits for the bitstream in compressed form.
what are the consi...
- 5 years ago
Hey MuralikumarM.
Perhaps I should say like this. The maximum total size indicated in the document consists of everything including firmware (ELF) and bitstream. The actual size varies depending on design such as the usage of NIOS and etc.
Bruce
YuanLi_S_Intel
5 years agoHi Murali kumar M,
Yes, for the firmware file (.elf), it is not part of the bitstream. You will need to program that after bitstream is downloaded.
Thanks and regards
Bruce
MuralikumarM
5 years agoHi Bruce,
If that case, what will be the total size of all files required that I should load into my device?.
From where I can get the approximate file sizes except bitstream..??
MuralikumarM
MuralikumarM
