MuralikumarM
5 years agoFlash size selection for the S10TX2800 device configuration
I want to select the flash part for the configuration of intel STARTIX10 TX 2800 device,
as per device data sheet table 104 shows 577Mbits for the bitstream in compressed form.
what are the consi...
- 5 years ago
Hey MuralikumarM.
Perhaps I should say like this. The maximum total size indicated in the document consists of everything including firmware (ELF) and bitstream. The actual size varies depending on design such as the usage of NIOS and etc.
Bruce
YuanLi_S_Intel
5 years agoHi,
First of all, you may refer to the user guide below for the maximum bitstream for particular devices:
Say you are choosing Stratix 10 GX10M, the flash memory that you are choosing should be higher than 654 Mbits.
For configuration devices, you may refer to link below for recommended configuration devices:
https://www.intel.com/content/www/us/en/products/programmable/configuration-device.html
regards,
Bruce
MuralikumarM
5 years agoHi @Bruce ,
Thanks for your response.
As per the data sheet i got the bitstream size.
But my doubt is, for the configuration flash, bitstream alone is not a firmware executable right?.. there may be some more files for HPS also. I am new to this SOC and learning, so if anything wrong you can correct me..
Thanks and regards
Murali kumar M
Thanks and regards
Murali kumar M
