16 years agoFlash Programming
I dont want to use a flash programmer to download my .flash file to CFI flash. I am able download the .flash file to CFI flash succesfully, using the alt_write_flash. When i power up ...
16 years agoIndeed, that's what I suspect.
Debugging is done step by step. You made a good first step, to compare the downloaded version with the original. Make the second step as I've suggested. BTW Which FGPA are you using? Are you sure the MSEL pins are correctly set? Success, Ton
