16 years agoFlash Programming
I dont want to use a flash programmer to download my .flash file to CFI flash. I am able download the .flash file to CFI flash succesfully, using the alt_write_flash. When i power up ...
16 years agoThanks ton for the reply,
If i use the flash programmer to download my software(*.flash) to CFI flash, the code runs properly after power up. Actually, But if i try to download the (*.flash) file using alt_write_flash API, it downloads it properly to CFI flash, ( i confirmed it by reading it back and comparing it with original (*.flash file). but when i power up , code doesnt run at all. Do you still think , its something to with FPGA configuration?
