14 years ago
Flash not works
Hi all.
I have a Arria II GX 125 kit.
When i compile Board Update Portal example then build standart memory test app in Nios - the project is work fine: cfi_flash tests pass.
When i make my SOPC-system, i make cfi_flash controller as ref example. cfi_flash not works... Nios say: cannot open cfi_flash.....
cfi_flash part of SOPC design are identically between Reference and my projects.
I try many ways, (adding constraints for flash signals, changing memory mapping, changing reset vectors to other memories, adding maxii interface) but no result...
I'm so confused...
Help, pls...
My project is attached.
https://www.alteraforum.com/forum/attachment.php?attachmentid=5921
1 Reply
    Solved by merging two Intel 256P30 controllers in QSys.
    From Nios it's visible as two flash devices.
