17 years agoFlash Memory VHDL. Write Duration. JEDEC.
Hello, I am using a flash memory amd29lv320d. It is CFI compliant. I designed a code for write, read and erase the flash in VHDL. For read and erase I have what I expected (talking in term...
17 years agoHello,
Just if somebody has the same trouble in the future. I found the trouble. I had forgoten the pull up resistor in the RY/BY pin. I used the pin assignment tool for add a weak pull up resistor . Bye.
