17 years agoFlash memory to configure the Cyclone III
Hi, I am trying to use a standard flash to configure a CIII chip which is supported in the datasheet. I was wondering if anybody knows the difference between top parameter and bottom parameter...
17 years agoBah. I had an old handbook and didn't realize a new one was out. The new handbook has a section which shows how the Cyclone III skips the starting addresses ignoring the top bottom parameter issue. So its ok to use either top or bottom parameter flash chips.
Subhani1
5 years agothe above you mentioned part is also obsolete plz provide any alternate part which support ap configuration.
