17 years agoFlash Device Access
Hej I am using my custom board where I have an external flash device attached..I want to read and write the flash device..I read the manual Nios II Software Developer's Handbook...and acording...
17 years agoAre you sure your pin connections or signals to CFI flash are correct? I have encountered such problem and later I found that the pin connection was not going right! You may also want to check the setup, hold and wait time, if they are all correct!
