17 years agoFlash Device Access
Hej I am using my custom board where I have an external flash device attached..I want to read and write the flash device..I read the manual Nios II Software Developer's Handbook...and acording...
17 years agoHej Ura!
I tried to boot the processor from the flash and tried to program the flash using flash programmer..but i got this kind of error.. Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK No CFI table found at address 0x03000000 Leaving target processor paused So then i tried the CLI for the nios flash programmer..and tried the debug option as well..and got the reply where there are some hex values..at differnt locations wrote into the flash..the manual says that i have to compare the values with the datasheet...which i did...and if i am thinking right...tht we have to just compare the values...i guesss the values were different....like after flash programing..value at location 10 was 33H where as in datasheet it was 51H...I am using AM29LV128M flash..which is i guess the altera supported device..
