17 years agoFlash Device Access
Hej I am using my custom board where I have an external flash device attached..I want to read and write the flash device..I read the manual Nios II Software Developer's Handbook...and acording...
17 years agoHi,
I think its worth trying to force it by defining the appropriate symbol as Jake has described in the referenced thread (except in your case define ALT_USE_CFI_FLASH rather than ALT_USE_EPCS_FLASH). To be on the safe side I'd then do a Clean Project before re-building. It should work. Cheers
